Vent window
If you are using new T's in the slide, file about 1/16" off of them before you put them together on the glass. They are to wide to slide in the felt lined tracks.
Put the felt on the edge of glass out of car better when it is in the sun for a while and put some clothes pins on it to make it conform to the glass and use some white grease and it will slide right in there just take your time if you get frustrated leave it for a while I messed up one and had to order a whole new set
