Air grabber
Are you referring to the boot on the actuator rod at the firewall bracket?
Like this one. They came on all of the Hemi's manual and power and I don't know why. As far as a source? As luck would have it mine was in good shaperoadrunner restoration 439.jpg
Someone reproduced this item several years ago. There may still be some out there. Try BE&A or Layson's.
B/E and A has them listed are they a frame around it or just the boot and thanks for the information
goggle air grabbers restoration ( don hall ) give him a call he did my air grabber for my road runner he may know what you need
Like this one. They came on all of the Hemi's manual and power and I don't know why. As far as a source? As luck would have it mine was in good shapeView attachment 25145
The Hemi brake master cylinder (and vacuum booster) is actually set higher and I think a little to the left (driver's side) away from the BIG HEMI HEADS. I have a couple of photos of power brake booster and master cylinders on 383/440 cars that shows them mounted lower and more centered. Wonder if the brake rod is at an angle under the dash from the brake pedal??????????
440 GTX '69 with PB booster below the firewall to cowl seam.
'69 Hemi (survivor) RR with PB booster above the firewall/cowl seam, that's why I think the air grabber cutout is necessary on the Hemi for head and exhaust manifold clearance.
