aluminum radiator
Goon
fort atkinson, wi
anyone running an aftermarket 2 row aluminum radiator with 1" tubes?? what type?? Thank You
Coyote
Columbus, OH
I have an aluminum one from Wizard, don’t have a clue as to construction. Just know it works!:thumbsup::beep:
I have a three row aluminum 26” works great and I know it’s supposed to be smaller but what the hay right!!
jww69rrpost
I'm using a Griffin 26" 3-row with trans cooler, came with dual electric fans and shroud and trans cooler. Same setup I used on a street rods years back and have always had great results with this manufacture. The current one is on my 69 Road Runner and it's the "exact fit" model... looks stock except for the aluminum look. Highly recommend this brand
So if I put AC in the car should the original radiator work as well or did they make a bigger one for AC car's. Russ.
Terry Hauck
Choadicus
Mojave Desert
I have one from Cool Craft with the 1 inch tubes and a 160 thermostat. I live in the desert where it gets in the 100s all the time and it works great.
6PKRTSE
Motor City
I had this one custom made locally for my 70' Challenger street strip car to support 1600+ H.P. They even added the -20 AN weld bung fittings I gave them for my upper & lower hoses. I then painted it black for that more OEM look that I am going for even though a race car.
