Straighten body panels.
Yes still at it. Found low and high spots with the new quarter panels. Also has some imperfections in the roof not bad looks like when pressed in the mold left ripples. These are over the rain channel area above the door to the back. Also down the middle so should not take a lot of filler. After done with blocking the filler then will spray filler over the hole car and block it one more time. Driver side done. IMG_0101.JPG IMG_0102.JPG
I'm afraid when you get done the car is going to go down the road backwards with one wheel off the road and suicide doors :rofl::rofl::rofl:
Looks good.You doing the body work yourself. What company you using for the metal work
Got the body panels from Auto body specialties. Have done all the work my self from front to rear. Thought I would never get done welding and grinding. Plug welded most of the metal but did buy a Pinch welder from Harbor freight. That made some of it go faster where I could use it. Worked grate for the new roof. Thanks. Russ.
