Rear seal transmission A833
Johnnyscarnuts
Johnnyscarnuts
Tucson AZ
image.jpg Hey guys I got a little drip from the back of my transmission.
I was going to take the driveshaft out and see if I can replace the seal.
I just fixed my jack so I can jack it up really high now before it would only go up enough to barely take the tire off.
Johnnyscarnuts
Johnnyscarnuts
Tucson AZ
The seal looks beautiful I wet sanded the yolk a little bit to takeoff a little bit of wear marks,I guess the seal just wears out the chef seems to be tight in the transmission not much wiggle
While you had it out I would have replaced it with a new one. That is the norm when removing a seal. It is up to the owner if do or don't. Well it looks like your making progress buddy keep up the good work. Russ. :thumbsup2:
Johnnyscarnuts
Johnnyscarnuts
Tucson AZ
630671D1-2F89-4908-A636-2D3BE0CCDF6A.jpeg Oh no I’m definitely replacing the seal I just said it looks like there’s nothing wrong with it but at closer inspection you could see the cracks around the edge of the rubber
Rich B
Minot, ME
May try a bit heavier hypoid gear oil. Have no idea what was recommended by Plymouth now. Make sure vents are all open or pressure will build up and yup, appears as leak from somewheres. Even gas tank is vented.
Yep always put some lube on it she said OH seal said and leave my sex life out of this. :lol: Use a good quality bearing grease like the blue or green light weight.
Just find a better place to run the add for the car. I told my friend to take the car out to some places where all the old cars hang out and put a for sale sign on it and wait. It is a lot of fun and a lot of people will look at it. I saw one on Mid West autos for sale looked like yours was it. Hang in their Maybe find a yacht club or polo field and hang out. :thumbsup2:
