sedan post trim
Big Mo
Pa. USA
Could anyone tell me what the moulding is called that presses on the pinch weld on the inside front and back of sedan post. My old pieces are not cracked or broken but are hard and disformed slightly. I would like to replace it if I can find where to purchase it. Any information will be very appreciated. Thank you for your time from BIG MO.
I'm not sure what they are called either but you might try Legendary Interiors. They might have what you need.
The item in question is called windlace and for the particular application in question is not available. You can purchase a generic style of windlace available from most automotive upholstery shops. Due to the nature of the profile, it allows it to fit tight to the B-pillar. I would suggest trying to slightly warm the windlace and attempt to push it into place. If not, you might be able to find a good used piece as they are quite sturdy and clean up well.
I think now that I know this trim is not available I will use my trim. It fits very well only deformed slightly.
