Windows and weather strip on doors
Big Mo
Pa. USA
Finished door windows and pop outs. All weather rubber seal on and looks good. Polished door mirror and it looks like new. I don't know if I remember how to install mirror. Maybe I should have put it on before I put glass in. Wish me luck.
Darn Big MO. That is a thought to put the mirror on first. It will just take two people to get it on. One to hold it on while one puts the bolts in.
Big Mo
Pa. USA
Might be kind of tight but think you will get it buddy. :thumbsup2:
Well we put the mirror on today. When we tried to install the adjuster in the door it will not get tight against the door. I don't know if maybe something is missing. I have a flat spring steel spacer, a sheet metal nut and the chrome threaded ring that goes against the door. I can get it to draw tight but the chrome ring is away from the door maybe 1/8'' I called DTM and they said there is not any shim to take up that space. Mabey I am not putting the parts in the right order. Anyone ever have this happen?
So you where able to put the mirror on. Can't help on the adjuster. How did the mirror fit the door. Did you have a problem getting it on. :praying:
Big Mo
Pa. USA
The mirror went on easy. Adjusting cables run around window channel and out hole in door.
