Insulation on floor
Big Mo
Pa. USA
I started putting insulation on floor today. Got done up about half to front started at rear. I used the foam with foil like on both sides that Lowe's sells by the roll. Hope it helps keep some heat out of car.
Did you look a the X matt Eastwood sell's. It was pretty cheap considering. What other product's go for. Any thing is better than nothing. Their was one kind on U tube and they said to stay away from it. It dose not stick after a while. Post some pic's. I had some posted in body interior and trim of the X matt. :thumbsup2:
Big Mo
Pa. USA
My daughter needs to show me how to get the pics from my phone to computer then I can post pics,LOL. Your friend Big Mo
That would be a problem for me also. Don't have a way to do that. Only thing I use is a camera digital and down load the pic's to a file. :thumbsup2:
I used 3M A/C silver tape on the joint's. Figured it would be a good idea. Dose the insulation you got have a peal and stick. It was slim line that I saw on U tube they had a problem with it. The guy was taking all of it off. Just to say. Don't know how good the stuff is that I bought but had a good rating on it when looking around. Don't work to hard their is plenty left to do. :thumbsup2:
Big Mo
Pa. USA
No Russ it is the type I need to spray adhesive down first. Hope it works. Your bud Big Mo.
Ok Big Mo. Watch those fumes from that glue. It will give you a head ache. Keep us up on the car's progress. Russ.
I feel for you on the water damage. First thing's first. The bird is not going any where it will be their when you get back to it. Hope you get the house done pretty quick. Had to take time out for things before also then got back to working on the runner. Russ.
