Try again. Beep. Beep.
I’ll have to take a closer look , they are original to the car . The rubber bump stop slides over the pin but let me check on pin size.
Are these factory pins available as a repop? Ive got a set of A12 pins + rear brackets, just wondering if there would be any difference. Seems like it would be much easier than trying to do some bracket wizardry.
Got me a set of the rear brackets, but I have a 68 so same hood support pads as you. No pins originally, just the bumper stop for the good on a much smaller guage screw. Was thinking I'd have to drill it out bigger to mount the front pins there.
It appears the front area where the pin is located is different on the 69 than the 68, take a close look at the pic. Of the orange 69 and the blue 68 it looks like a different piece of metal was used between the two that the pin mounts to.
Factory Petty Blue ,it has the special paint code 999. That means its a non factory color. Richard Petty still owns the copy rights .
