piece of plastic below the pop out window
I have the one for the driver's side but looking for the one on passenger side. It has two clip's on it. It cover's that U shaped hole in the inner frame below the pop out window. Or dose someone know where to get one. It should fit left or right depending on you put the clip's on the piece. :BangHead:
IMG_0101.JPG Here is a pic. of what I am talking about. If any one knows where to get the other one would appreciate in put. Looked in the parts manual and did not even see it listed.
Big Block
Jackson, MO
Yes Russ there is one goes on each side in the corner of the little window I do not know where you can buy them .
Yes thanks for the info. Must not have been one on the passenger side because I only have the one on the driver's side. That is what happens when you get a car someone else started to restoration on.
Plybeep68
Acceleratii Incredibus
Russ, can you find similar material and make it yourself ? From what I remember those are flat aren't they ?
Well Plybeep68 looks like that is what I will have to do. Thing is don't know what type plastic that it is made out of. Also if I new the part name would help. To me it is a filler panel or blank. I do know where it goes. Just will have to call Stephens Monday and see if they can tell me more on it. They may have it but oh my gosh what they will want for it. Like every thing else missing off this car. Thanks for the idea. Will come up with something I am sure. Russ. :thumbsup2:
Big Mo
Pa. USA
Russ I need to look and see if I have any of them. Don't know the name will look. Big Mo
Yes could not find it in the parts manual either. We have determined it is a splash shield. 1968 man say's he has one. Thanks Big Mo. You know that they probably get thrown away at the salvage yard's. I did keep the one that was on the driver's side of the car. That is what happens when you buy a car that has been taken apart before you get it. :thumbsup2:
69bfan
GA
I have the reproductions available. They are $10.00 per side with the correct style attaching clip. Just let me know.
Thanks,
Richard
Well heck did not know any one was making them. Got you in the PM and will remember that. Some of the guy's have reached out and will wait a few day's to see how this transpires. Thank you.
You the man 1968 Man. Saved my bacon. I can say that you had part in restoring this runner. Had a buddy who gave me the road runner sticker's for the door's. Jeff pasted this past year. So he will be apart of this car also. Thanks. Russ.
