Flywheel with offset bolt pattern
Floyd
New Member
I'm needing to replace my clutch and flywheel on my 1969 RR. The car was oringinally a 383 but now has a date correct 440 in her. I'm needing an 11" disk, 143 tooth, but I can't find one that has this offset bolt pattern, see pic. All I can find are symmetrical bolt patterns. Any suggestions?
RKNRLR
Sydney, Australia
Any reason for the offset pattern? Changed mine a couple times and I also have a 143 tooth flywheel but with the symmetrical pattern. Block is a '72 440, but the crank is still forged. Not sure if it was original to the block.
Just curious.
The level of stupidity that has infected this site is not to be believed.
RKNRLR
Sydney, Australia
Not all forum members arre guru's, alot of us are here to learn. And you don't learn much if you dont ask no questions.
