mytfyn69
the speedometer faceplate on my car has seen way too much abuse. The clear plastic is in great shape, but the painted chrome on the surrounding trim piece is really bad. Where to get a replacement ??
			Thanks for that tip. I will check it out. Seems much easier to try that as opposed to trying to remove & replace…Can you put up a picture of what you're needing to chrome? If it's a thin area around the gauges & bezel, a chrome pen might do a decent job for you. MOLOTOW makes them in different widths. I use them on some models with very good results. Just my 2 cents.
