I took the RR out for a drive on the freeway to some open space. Up some inclines, down some. The engine stayed within reason with regards to temp. A little higher going up, a little lower going down.
I filled up before I left and when I came back. If I go by the speedo directly, I got about 10 miles to the gallon. But I have 15 inch wheels on the car so I don't know if the gas mileage is a little better because it should be calibrated for a 14 inch wheel.
Still sucks. But it might get a little better once its broken in some.
Seems like the exhaust is knocking against the car/engine/bell housing. Needs knew exhaust anyway, but don't know in what order I'll install new exhaust. Next is the gas tank and cleaning up the under rear of the car.
I'll keep my fingers crossed.
Barry
Barry
