1970 different rear leaf springs
Transmission and Drivetrain
  1. richardgoesfast
    richardgoesfast Active Member
    43
    May 5, 2019
    Hey folks,
    A friend told me that the Road Runners have different rear leaf springs (Super Stock I think he said they were called) in order to counteract torque under hard acceleration.
    So I looked under the car today and sure enough, I counted a 7 leaf spring on driver and 5 on the passenger. I counted a couple times so I think this is right. But something tells me they should be reversed in their position. Like the 7 spring should be passenger and the 5 on the driver side.
    Does any of this make any sense. . . ?
    Rich B likes this.
  2. Rich B
    Rich B Well-Known Member
    192
    Jun 23, 2019
    Minot, ME
    Good question, would say maybe driver side under normal hi-stress would be the wheel with the higher gripping torque? Chrysler engineers were ahead of their time back then. Traction bars were awesome, had chrome set on my ‘Lil Red Truck. Definitely period correct but never see any in photos of road runners? https://www.bing.com/images/search?q=traction+bar&qpvt=traction+bar&FORM=IGRE
  3. 69hemibeep
    20,794
    Yep they are reversed, they are XHD or nicknamed Hemi springs
    Russ69Runner likes this.
  4. quikbird
    quikbird Well-Known Member
    2,613
    columbus, ohio
    yes, larger spring belongs on passenger side to counteract torque on launch
  5. Big Mo
    Big Mo Well-Known Member
    93
    Dec 14, 2013
    Pa. USA
    Yes on passenger side. I bought a set and ordered them 1" over center to give the body a little lift. There was air shocks on when I got the car. The top shock mounts were bent slightly. I am not a big fan of air shocks. We also put same springs on my friends 66 Bel. and it sits very nice.
  6. Russ69Runner
    4,333
    Put Six leaf on this runner with 2 inch recurve. Wanted lift with out using air shock. Had them and they busted or would leak down over night then had to air them up to get to work. It might ride a little rough but figure once the weight is added back to the car they will set a little lower.
  7. quikbird
    2,613
    columbus, ohio
    air shocks are not a good idea on roadrunners. the upper support bar the shocks attach to is not strong enough to carry the weight of the car. not a good scene when it breaks
  8. ACME A12
    13,066
    You guys are just trying to hurt Basketcase's feelings with all of this anti-air shock talk... :rofl::rofl::rofl:
  9. 69hemibeep
    20,794
    :rofl: I think Dave's computer broke, he's been quiet
  10. quikbird
    2,613
    columbus, ohio
    now that you mention it, we ought to be nervous about that
  11. Russ69Runner
    4,333
    Yes the shock tower is pretty weak. Your rite on spot about it holding the weight of the car. Even the dodge's had the same problem.
  12. Roadcuda
    Roadcuda Well-Known Member
    10,366
    Yeah, that happened to my first Road Runner back in '72. The PO fixed it my bolting the broken shock mount to the trunk floor. It tore it all to hell.
  13. Russ69Runner
    4,333
    Oh my gosh that is a hard lesion to learn. Even though the runner I got found a crack in the support. Must say it is as thin of a piece of metal ever seen to function for what it was intended to do. But metal dose become brittle after time from being worked and twisted. Something has to give.
Share This Page
