1970 RR headlight switch question
Lucky LAr
SF BAY AREA
I pulled out my headlight switch (original) after checking the fuse
Because the tail lights & dash lights stopped working
I Was able to take it apart, clean it up,
put it back together, without breaking something (amazing)
now it works again (amazing X 2)
I noticed that there is a set of contact points inside of the switch
Can somebody tell me what these points do & how they work?
I cleaned the contacts just like a set of ignition points, not sure if that fixed my problem or just cleaning up the other electrical connections fixed it ???
Any electrical experts out there that know what these points do & how they work?
just want to learn something new to m
Thanks Larry
That would be the internal circuit breaker for the headlights.
:beep:I would think that it is bimetal and opens when it get's to a certain temp. The metal bend's when it get's hot enough.
do you know what makes the contacts open?
The short answer is a short or some sort of overload in the circuit.
Russ explained how it works.
