3 speed wiper motor
Bill Monk
Dunbar, WV
Still working on the starter issue but after I get that sorted out, I'm going to need to swap out my wiper motor. Beside the obvious removal from the firewall, what is involved in the swap? Can I take it loose from behind the radio? This is one thing I have never done. Thanks in advance.
I do believe if you pull the radio you can get to the nut that holds the crank on then the rest is under hood.
Really easy just four nuts and the wires and it's out
The crank nut under the dash is a lock nut so do it first, you don't want the motor wobbling around while trying to remove it.
