trim88
Hi, Have a low miler (47,000) 383 and have had some leaks into the valley pan. Upon removing and checking the intake fit to the heads, there is a .005 gap between the intake surface and the head on the right front and left rear...... almost like either the heads are not in parallel or the intake is tweaked. I am not experienced in this area, so I guess my question is, is this .005 too much of a gap to close up with the valley pan gasket??? or is that much of a gap pretty much normal?
I have used a straight edge on the intake manifold and both sides are perfectly flat.
Any input would be appreciated, Thanks, trim
