383 Windage Tray
trim88
Branson, Missouri
Hi, Have a 69 RR w/383 HP engine. Just wondering if all 383 HP engines have a windage tray as I found in mine?
Thanks, trim
moparstuart said:
did a non HP motor have a big in-take that covered it all ?
Son, I think he is referring to the one in the oil pan :yesnod:
ok yeah i get that shit confused got you now
We all have our moments, wait till you get older :crazy:
trim88
Branson, Missouri
Thanks All, I was kinda surprised when I pulled the engine and removed the pan. It had 2 cork gaskets and I swear the bolts could be taken off with my fingers, but luckily didn't have any leaks yet. I am basically just trying to detail the engine compartment but the prior owner told me it had been balanced and blue printed but didn't have the papers.... so wanted to look at the bottom end. Sure enough the rod caps had been ground down, apparently for balancing. Without removing the timing cover/or complete tear down is there a way to tell if the cam has been changed?
trim
trim
Take the valve cover off and use a dial indicator to measure the valve lift. Duration can be done that way too, but it's more involved.
trim88
Branson, Missouri
Thanks Big John, I tried that but it didn't seem right ....so then I thought maybe it's the hydralic lifters making some difference. Will the hydraulics cause a funny reading?
Yes. With an adjustable rocker you can bottom out the hydraulic lifter and get a better reading.
Windage trays were only placed into the HP 383's IIRC. I do not believe a 2 bbl 383 had one.
A31PKG
Mid-Atlantic
I agree, one of the selling points for the new "Road Runner engine" was the addition of the windage tray.
