jerrysdustydog
I need some feedback from original roadrunner owners with the A833 tranny. I believe I have a 491 8 3/4, but not a sure grip. As some of you know, I just got all my issues resolved and got to drive the car finally. I have only put 6 or 8 miles on it, but have noticed that first gear feels alot like 2nd should. Very tall, but when shifting into 2nd or 3rd it seems normla, just getting it up to 10 or 15 miles an hour is tougher than it should be. Are all 1st gears that high in ratio? I have not looked at the transmission specs to see what ratio they should be, but wonder if someone may have changed the gear out. I have got the car up to 70 or so and it does wind out, but no tach to see what it's actually turning. I guess depending on what you guys say, I will verify the rear end ratio, and maybe add a tach to see what it's doing. I may have to go back into the timing chain, for the guy that helped me build my engine may have not got the "marks" lined up on the gears correctly (what I get for letting someone else do it). Engine does not sound 'right', and sure doesn't feel like it has the power it should. The car kinda acts like it has the power of a 350 chevy with a 2 barrel. Yeah, it never ends.
