SgtLee511
I just had a short block 440 completed, long story but the short of it is this, I found out during the machine shop rebuild that this engine had a set of low compression flat tops installed, to counter this my machine shop took 20 thousands off the block, to help in raising the compression to my goal of 10.0. Im planning to the use E street heads, my machinist Chevy Guy says we need to find out what push rods to use, I plan on using a Comp Cam High Energy .507 as my camshaft. Will the pushrods be affected in this build, I figured stock would do?, I was hoping to use stock valve train, any suggestions here? I dont have any head bolts for those E Street Heads, where do I look for those?
