coyotekiller
Has anybody here bought a alum. waterpump housing from 440 source.
I bought one and it was a piece of crap. It would not fit over the timingchain cover. I had to grind the back of it. than when I put the thermostat housing on the bolts did not line up so I drilled out the bolt holes so it would fit. than when I was installing the temp sensor the hole where the sensor goes was too small. That is when I gave up on it and bought a MP housing. put that on and everything was perfect. Just wanted to know if it was just me or has anybody else had a problem with 440 source. Thanks
