6t9runner440
I have been struggling with this decision for quite some time and I think it's time to part with this car. I just don't have the time or money to give this car the attention it deserves. I have done quite a bit to this car
new stock exhaust including manifolds
83/4 rear from drum to drum
new kickdown
new brakes and front drums
new v gate shifter
new electronic ignition
new trans mount
new driveshaft
new mopar performance xhd leafs with shackles, front hangers and bolts
This is a very solid GTX but it will need some work...it is not numbers matching...It has a 71 HP 440...tested compression at 145 per cylinder
I belive the trans is good but it has a torque converter issue..the mopar clunk
It will need front end work...it's very driveable but I know the strut rod bushings are shot
Needs the front wheel housings completed
This is a highly optioned gtx...Light package, air grabber
Low retail for this car is 14300 and I would like to get around this for the car
If you are interested or know someone who is you can pm me and I will give you my number with all the fender tag info
There is no build sheet but the numbers on the rad support match the fender tag
It is a rs23 car
here is a link to some pics http://s113.photobucket.com/albums/n219/njpete164/gtx/
new kickdown
new v gate shifter
new trans mount
new driveshaft
It is a rs23 car
