Wideboots
Just bought a 69 Road Runner a couple of months ago. Currently trying to diagnose problem with the horn. Someone has wired the horn directly to a button under the dash (no relay, just a wire going to the button). This button is also wired to a brown wire coming out of the steering column. The button under the dash does not work nor does the regular horn button on the steering column. I would like to make the horn button on the steering column work as it should. I tested the horn and it does work when power directly to it from the battery. I have a diagram of how to wire a 4 pin relay to make the horn work. I need to know which wire coming out of the steering column is from the horn button. I checked the wire under the horn button on the steering column and it looks to be in the proper place. Unfortunately, my electrical skills are limited. Advice here would be very helpful. Thanks.
![20240705_151735[1].jpg 20240705_151735[1].jpg](http://www.69roadrunner.net/mopar/data/attachments/37/37958-84f266511fdbdbdaa505ed0a34ee54c6.jpg?hash=hPJmUR_b29)
![20240705_151855[1].jpg 20240705_151855[1].jpg](http://www.69roadrunner.net/mopar/data/attachments/37/37959-0df9fbeaa8a86e8be092463eddc3f3b9.jpg?hash=Dfn76qiobo)
![20240705_152042[1].jpg 20240705_152042[1].jpg](http://www.69roadrunner.net/mopar/data/attachments/37/37960-1cb03f106d77f351346bb7c34bfbdba5.jpg?hash=HLA_EG1381)
![20240705_152105[1].jpg 20240705_152105[1].jpg](http://www.69roadrunner.net/mopar/data/attachments/37/37961-e6931932f42721514f1b2b578bc804d0.jpg?hash=5pMZMvQnIV)
![20240705_152115[1].jpg 20240705_152115[1].jpg](http://www.69roadrunner.net/mopar/data/attachments/37/37962-f060bc22bfe63dad69815eb120c9489c.jpg?hash=8GC8Ir_mPa)
