artiststan
Replaced hazard flasher part.. flashers now only work when key is on and I must put on turn signal.. then it flashes fine.. a fast flashing. . All lights and blinkers working fine. I assume the hazard light issue is an issue unless the flashers operated differently in 1969. Any thoughts?
