I had noticed that some of my trans pan bolts where a little loose so I retorqued to spec, but looks like the old gasket didnt like that so now I have a decent leak.
Is there an easy way to do this, since there is no drain plug im guessing I should just try and drop one corner and get most of the fluid out that way. Any tricks that im not thinking of?
Also im obviously going to loose alot of fluid, Assuming I catch it all I can make a good guess at what came out, but how much fluid is actually in the pan if full, I know the spec is 15.5 pts (no aux cooler, just the radiator), but how much stays in the converter, etc?
Thanks
Thanks
