WANTED Air intake
V.R.D
florida
good luck hard to find. there is someone that refurbish your old one some body will chime in and help. you could check the other forum for b-body's only.
Rogue Runner
Jacksonville, OR.
Hope not, we dynode the motor and got everything pretty dialed. We also have a guy that helps locals' with these quite often if we run into a snag.. He has all the right equipment for these units.
V.R.D
florida
the heat is the problem if the ecu is in the unit bolted to the intake will over heat the ecu . if you use a 1/4 wood/fiber spacer it will help with heat soke.
Rogue Runner
Jacksonville, OR.
OK now you have my attention, i was aware of the sensitivity of the wire harness and ecu, but no one ever discussed a solution. What your saying is once i slam the hood shut and step into the real environment it will face, it's going to get very warm there. Thank you for the info.
V.R.D
florida
i run the edelbrock pro-flo 4 xt port fuel injection it is so fun and e-z to tune
that fiteck is or might be a problem.
If you are talking about hood clearance for the FiTech with an air grabber, it will not be an issue. But the single plane hi rise intake is another can of worms altogether. No way that will work with a factory air grabber.
Rogue Runner
Jacksonville, OR.
No, no air grabber with this motor. It's not original to the car, we took the air grabber off the hood until it's time to take her back to her original glory.
Rogue Runner
Jacksonville, OR.
Maybe looking at refurbishing mine is a better idea, it's not bad, just very brittle and rubber needs to be replaced with new decal.
Check old forum here on the air grabber. There is a guy that can bring these back. Decals might be found in the classic industries book. That new motor is eye candy. Have fun. :beep:
I run a Holley Sniper on my 440 Valiant down in the desert in high heat with no issues same design more or less as the Fitech. I have read about some issues with the Fitech so I went Holley. Come to think about it I am useing an aluminum manifold but still 225 degrees at times.
Rogue Runner
Jacksonville, OR.
Great story... very nice RR
