I spent some time trying to adjust my kickdown linkage this weekend and have a few questions.
According to the service manual (the way i read it) I was to place a pin in the linkage and adjust the intermediate shaft to line up with the ball on the upper hinge, Then adjust the upper shaft so that the slotted portion that connects to the carb linkage is just touching the linkage. That means the kickdown moves with even the slightest throttle.
Is this right?
It seems to me it shifts out of first too quickly when at full throttle.
It also seems to shift into third too late then under normal acceleration.
Do these issues have anything to do with the kickdown or are there other adjustments I should be making.
Would someone please be so kind to point me in the right direction?
Thank you
Mark
Is this right?
Thank you
Mark
