Back fire through carb
dmartin
I can not give it wot from sitting still have to baby it to start moving cannot floor board it from a stand still or it will cut out and back fire through carb also can not floor it when in second gear without cutting out my timing is correct plugs and wires and distributer is good doesn’t appear to have a vacuum leak, I’m thinking maybe my timing is to retarded?
Check the accelerator pump shot. It may be too lean. Either worn or needs more.
Some carbs have different holes to insert the linkage. If so experiment and see if there is any improvement.
Good luck, advise what you find.:beep:
If you have points it sounds like they need adjusted or a bad condenser
Hey big guy I have a 750 Holley I think all that is good cause it even backfired with a Edlebroc carb
Sounds like that something with the carb. Maybe a plugged filter. Check the screen at the inlet on the carb. Mine was doing this and the timing was out and the carb adjustment was bad. It ended up being bad floats. Could be the power pump on the carb. Let us know what you find out. Russ.
I adjusted my accelerator pump on carb I think that did it, it does not hesitate near as bad
Cha ching. Not bad for a long distance diagnosis. My modesty is exceeded only by my humility. :thumbsup2::beep:
we have been friends for a few years. we need to get his satty finished so we can start on the stupidbaker autocrosser project car for this summer. If we can get him off the couch playing with the cats and get some work done.
Stupid baker is nickname for auto crosser project for good guys. 1946 studebaker sedan project. Will have a mustang 2 front end, small block Chevy, 4 gear, ford 8.8 rear axle. Engine will be set back in frame, new firewall etc. ask coyote for picture of this thing. It was ugly new and hasn't improved any over years
It was gonna be a secret weapon. Qbird now has pics to upload. Its beyond my capabilities. I just cobble with plasma cutter and mig welder. Hot fun!
The ‘55 was evil enough to run against ANY shoebox on the planet. Beat aftermarket chassis and LS powered pro built cars. Won Tri 5 Nats and would do mid pack against pony cars and vettes, sold to fund Stupidbaker.
Building pre ‘49 toy for smaller class and should be seriously competitive. The ‘55 was down to 3,200 lbs. before the Stupidbaker goes on a diet it scales at 2,560
Yee hah, here we go again! It’s so damn ugly, nothing done to it can make it look any worse!:soapbox::steering:
I just went through this on a brand new Holley 750 dp stupid pump cam needed to be changed and the pump arm needed adjustments. Sucked none of my qft carbs ever needed that. I think Holley has gone down hill
Backfire through the carb is usually a lean condition in the tip in circuit, could be caused by timing or carb adjustments or basic set-up of the carb.
You say the timing is correct? What do you call correct? Where's your initial at and where's the total, do you have the vac can connected? Which port Constant or ported? What RPM does the timing all come in at?
What ignition box are you using and with what coil?
You say you adjusted the pump shot and it's better, sounds like it's not completely gone? Maybe you just put a band aid on the issue and really didn't solve the real problem.
What carburetor on you working with?
Lots of questions??? These are just the basics once we know these then we can ask a lot more to determine where the real problem lies.
