jays69bird
Went to the Nationals today,I had a problem occurs twice today pulling into traffic that almost lead to some disaster.The first occcured aftyer I shut the car off to run into to register it.After about 10-15 minutes I came out started the car up started hard,it has been since I switched carbs but I think it may have to do with the ethonol fuel.went through the parking lot a couple of stops.I went into traffic making a left turn,light turned started to move the car bogged on me and stalled,I got traffic bearing down and Iam dead halfway through an intersection,didn't want to restart,I put the pedal to the floor she finally caught I dropped the clutch and got out of there.Later it happened pulling out of Ci Ci's,car was shut off about 45 minutes,she didn't stall when I pulled out but it fell flat and didn't want to move,again on a busy street.All I can think of is maybe a vapor lock because of the ethonol gas,I even thought about a backup electric pump like my dad put on his 36 Hudson.Stock motor with a reman AVS.Any ideas? I have an insallated spacer betweeen the carb and manifold.since I'm not running headers the heat riser is still working.
