Brake bleed sequence
Steve
Chesterfield,England
I'm going to change the Brake Fluid while the car is stuck in the garage.How much Dot 4 will be enough to do it and what is the bleed sequence for the wheels.
Not sure of the amount less than a quart I'll let you convert that, but you start with the wheel farthest from the cylinder and work your way to the closest.
x2
p/s rear, d/s rear, p/s front and d/s front. If you're using a vacuum pump type, you can recycle it into the master as you bleed it. Providing it's clean of course. :thumbsup:
