beepbeepbill
- Joined
- Apr 11, 2012
- Messages
- 29
- Reaction score
- 0
Hi guys n gals
got a problem on the new RR. the brake lights stay on even when car is sitting turned off and keys out of ignition. pulled front seat to make room for my large frame... and the peddle is not pressing against the cut off switch. It looks as if the switch itself is in the right location but the peddle is too far away to hold the switch in away from the contact point beside the peddle. The peddle itself is fine and the brakes seem to work fine. My question (before unbolting the peddle) is this. Is the contact point adjustable? is it oblong? I can't tell, but it looks as if it has been "welded" together. not to the bolt, but like it had been cracked and someone tried to fix it. If it is beyond repair, where do I find a new one?? If it is not oblong and adjustable, any suggestions on a repair??? :brickwall:
Bill
Bill
