roadrunnerh
Hey guys, I need some help. The front threaded captured nut welded inside the front frame rail is stripped. :brickwall: One of the two bolts that the bumper bracket bolts to the car. Anybody have a good fix for this?
Beat me to it :yesnod:ACME A12 said:Unless you're open to the idea of cutting that one out and welding another one in I think you're gonna have to put a heli-coil in it or just tap new larger diameter threads into the existing captive nut and go with a larger bolt.
Maybe someone else will have a brainstorm...![]()
To install a Helicoil you first re-tap the hole to a larger size.roadrunnerh said:Thanks for the lightening quick responses fellas!
Dave, are you a magician? How did you do that?
Any suggestions on a Helicoil kit to buy?
Risking sounding dumb here, but if I go the Helicoil route, can't I use the same bolt? Wouldn't the Helicoil fill the space after I drilled it out?
Take your bolt to a good parts store and they should be able to fix you up. They come with the coils a install tool, tap and drill bit.roadrunnerh said:Thanks for the lightening quick responses fellas!
Sounds like your in my world :yesnod:roadrunnerh said:So the bolts that mount the bumper brackets to the frame are 1/2" 13.
I purchased a Heli coil kit from NAPA, but of course they didn't have the 17/32 drill bit I need.
Neither did (in this order) Sears, Home Depot, or Harbor Freight. :brickwall: :brickwall: :brickwall: :brickwall:
I'm surprised the kit didn't come with the bit. If you want a single you may have to mail order it, not a typical size outside of buying a full fractional set. McMaster Carr, MSC, Grainger they'll all have it.roadrunnerh said:So the bolts that mount the bumper brackets to the frame are 1/2" 13.
