Cam breakin
Engine & Related
  1. Terry Hauck
    Terry Hauck Choadicus
    86
    Sep 6, 2017
    Mojave Desert
    Has anyone had a problem ruining new ceramic headers while breaking in a new cam?
  2. dmartin
    dmartin Well-Known Member
    612
    Aug 30, 2013
    How did you ruin them?
  3. Russ69Runner
    2,135
    Do the header's have a problem or are you just asking to make sure you don't hurt the header's.
  4. Terry Hauck
    86
    Sep 6, 2017
    Mojave Desert
    Asking if anyone has heard of this happening.
  5. Terry Hauck
    86
    Sep 6, 2017
    Mojave Desert
    TTI warns you to use an old set of headers at break in or you might ruin the coating. I will be very careful. Thanks
  6. 69hemibeep
    20,004
    Yeah I'd turn the mixture screws out anyway but at 2k the carb should be transitioning into a cruise circuit not so much idle
  7. Coyote
    Coyote Well-Known Member
    554
    Mar 6, 2016
    Columbus, OH
    Hmmm? I was not aware of the potential problem. Of course I’ve never had ceramic headers. It may possibly happen because car is stationary with no airflow over headers and continuous running at 2,500-3,000 rpm. If lean it would definitely cook about any finish Shades of blued chrome! Good luck! :thumbsup::beep:
  8. Russ69Runner
    2,135
    I agree with the lean mixture. If you put a cam in with bigger lob's then you need more fuel with more air getting in the motor. We put bigger jet's in our carb's when running a bigger cam lift. If it is just a street cam then would open the jet's. Still sometimes you have to put a bigger jet in their. Good luck with the new cam. :thumbsup:
  9. IQ52
    IQ52 Member
    24
    Apr 10, 2016
    Challis,ID
    Generally overheated headers comes from the ignition being retarded, the combustion process isn't completed in the chamber and continues in the header. I may have some authority to speak on this as I have my own dyno and run EGT sensors on all cylinders while the engine is on the dyno. I don't recall any case where the engine was lean and cooked the headers.
    Coyote and Russ69Runner like this.
  10. 69hemibeep
    20,004
    Well there you go an expert! But still I had a friend turn his chrome headers blue in short order he left a manifold plug out and caused a real lean condition is what I was going by.
  11. Russ69Runner
    2,135
    I like that a friend turned his header's blue. Thought all of them did that after running them for a while. I see these show cars with all the chrome exhaust on them and no blue mean's they never run the motor. They push them or pull them in for the show. :lol:
    dmartin and Coyote like this.
  12. Russ69Runner
    2,135
    Yea Coyote aint building no trailer Queen. Going to drive the fool out of it when she is done.
  13. Terry Hauck
    86
    Sep 6, 2017
    Mojave Desert
    Same here. Got Veterans day week off so I will be assembling the engine finally.
  14. Russ69Runner
    2,135
    Good luck Terry. With the motor rebuild. :thumbsup:
  15. RKNRLR
    RKNRLR Well-Known Member
    213
    Mar 27, 2017
    Sydney, Australia
    didnt put new headers in my car till after the cam was broken in, but also didnt change the dizzy or carbie, wanted to keep as much of the old stuff there as the car ran good before the new cam. would make any troubleshooting easi(er).
    Also got the new headers coated in black, so probably wouldnt have shown any signs of burning. Cant be too safe though.
  16. 6PKRTSE
    6PKRTSE Active Member
    29
    Oct 1, 2018
    Motor City
    We have done it both ways. Break in with an old set of junk headers, then install the new ceramic coated headers & then also with just using the ceramic coated headers on my buddies 69' Camaro & it did not burn off during break in but they did discolor some & are not the shiney silver as they were out of the box but still look great after several street years of use..
  17. MrJLR
    MrJLR Built - not bought
    20
    Apr 24, 2018
    Chino, Southern California
    Make sure your timing isn't retarded and don't run it lean and it should be fine.
    I broke in my cam with brand new ceramic headers...no issues.
    Also had a fan in front of the car...
    Jeff
  18. ACME A12
    12,640
    Had the exact same experience on a 340 Duster break-in about a dozen years ago. Just dulled them down a bit for the first couple of inches up near the flanges. Factory coated Hedmans.
Share This Page
