Confederate1969
I've heard a lot of talk from friends, relatives, reading, and tv shows about cam swaps being one of the first things you do as a performance upgrade for an old engine. I've done some browsing at places online like compcams (which is based right here in Memphis) and I'm more confused now than I was before I started shopping. Seems like there are a thousand different "usage" scenarios that one can set up an engine for. I don't need to run 10s at the motorsports park or need to have enough power to raise the city smog alert 200 points doing burnouts. They ask lots of questions like "Is this a show car? Is this a drag strip king? Is this a Sunday cruiser? Do you want to reverse the Earth's rotation when you hit the gas?" and so on... Well I just want a 383 I can run rough now and then to impress friends with.
What kind of cam would you all suggest for a little more aggressive 383 than the factory intended it to be (but without having to upgrade carbs and such)? And is it typical to upgrade the valve train with the cam from the same company in order to make sure they work right together?
