SomeCarGuy
750 Eddy. Put new accelerator pump in. Not much if any better. Went and put fresh gas in it. Carb ran fine before on 440, rejetted to stock 383 specs.
Could the metering rods be wrong for this app and be causing this. It bucks, backfires through carb every once and awhile.
Timing is is 10/34, will likely try 12/36 once this is sorted out.
I don't think there is a vaccum leak but I will look hards. Can't be very many places to leak on this car, no PB.
Huge deadspot if you try and go 1/2 throttle or so. Does fine if you let the clutch out or if you go about 3/4 throttle. Seems ok at a steady cruise.
Do I just need to let the older gas run out?
