I need some help :huh: I need a pic of how your carpet is cut at the steering column and the gas pedal linkage
three pedal cars are so much fun , too bad most of mine only have twomcmopar said:My replacement set from Auto Custom Carpets (ACC) came with a pre-cut slit for the linkage.
Thanks John. I put the hole in and was thinking about a slit for the part that swings. Now I can finish her up I got mine from Trim parts and it fit pretty well, but nothing is cut. I even had to put in the dimmer grommet!mcmopar said:My replacement set from Auto Custom Carpets (ACC) came with a pre-cut slit for the linkage.
Thats the same thing I'm going to do. Its all glued down now and I guess I will order sill plates and make them fit like everyone has to do. I was hopeing for a AMD would come out with them.John69RR said:Bob, for the seat holes I used a soldering iron. The heat melts the fibers and they won't come apart.
John. Try Trim Parts or Legendary it came in my kit, I had to put it in. The carpet fit well everywhere but the 4spd hump, good thing it has a console.mcmopar said:
I didn't get a dimmer grommet either. I really need to put one in because I kind of mucked up the hole for the dimmer switch. Do you know where I can get one?
