Carpeting
Whitey
44A945D1-6D5B-4DFA-BBD9-4C16A42D49D0.jpeg 642DF339-EA88-48E7-9DA5-2E3A681375AE.jpeg 4EB7FB3C-B318-4304-8382-06926F0C3B1C.jpeg I have a 1972 Rd., Runner needs carpeting where’s the best place to get it from thank you
Plybeep68
Acceleratii Incredibus
Check Rock Auto, the last time I compared prices they were the cheapest even with shipping !
I like ACC for quality. They're available from many different sources...including Rock Auto...
69bfan
GA
All of the carpet is now an ACC product. So no matter whom you purchase it from, then it is all coming from ACC. I would suggest not buying the carpet until your ready to install it. Carpet that has been stuffed inside a box for years makes for a much tougher install. As soon as it arrives, remove it from the box and lay out, flat as possible.
We are a vendor for ACC carpeting and once I call the order in, it usually is cut, molded and shipped in less than 48 hours. Covid has slowed things down slightly as some colors have been an issue in getting the bulk carpet. Depending upon if your looking for more noise insulation or a temperature barrier, some of the guys prefer the mass backing. This adds a heavier rubber like coating to the back of the carpet as found on the new vehicles. A bit more difficult to install but does have its merits.
Whitey
I have a new question... The 400 engine in my 72 road Runner is blue but the valve covers and air cleaner are orange and appear to be the original type I wonder if that’s factory or not?
Whitey
Another question... Will a 15 x 8“ rally wheel with 295/50 R 16 fit on the rear of a 72 road runner with stock suspension
Whitey
I was wondering if it would fit in the wheel well without rubbing
