clutch rod problems
generaljmwlee
NEPA
does any one have a correct z-bar for a 69 runner sitting around they can show me a pic of and maybe some measurement? I installed mine an the adjusting rod goes up on an angle. almost a inch lower than the clutch fork.
SomeCarGuy
Sometown in KY
Do you have the bar pivot in the frame seated all the way down? Could be in the notch but not all the way down. I could see that causing what you describe.
generaljmwlee
NEPA
I bought the whole kits to rebuild the clutch,bushings rods,clips ect my z-bar looks like yours and the ball stud is all the way down,is there a differance in bell housings? z-bar is level across, I will get some pics later tonight
SomeCarGuy
Sometown in KY
I'm having trouble seeing the problem, that is a hard place to take a pic of for sure.
I think it needs to be flipped over and use that little kick in it to line things up.
yeah try flipping the rod. I got a kit for mine, and the adjuster rod was shorter than the others I've had. the pedal was way too low, and not enough adjustment. the car had a homemade one on it. I swapped out the adjuster rod from my '85 D100 when i parted it, and the clutch hooks up great.
6R9Runner
Atlanta, GA
The adjusting rod in my car does not slope at such a steep angle as yours- its only about 1/4" lower in front and definitely not an inch lower. Also, the distance from the bottom edge of the horizontal Z-bar to the lowest edge of the arm is 4-1/8", measuring slightly on an angle (as that arm has a zig zag in it). Looking closely at mine, as with your setup, the adjusting rod does not line up exactly parallel with the arm as you might expect, and I used the "kick" towards the arm as mentioned by SomecarGuy.
The arm in your picture looks lower/ longer and slightly shifted towards the passenger side in relation to my car. If you are positive the clutch fork is engaging properly with its pivot inside the bellhousing, and that the Z-bar is in its proper position, then it looks like the lower arm of your Z-bar differs from mine. Good luck.
Another thought- did you install the spring retainer on the frame end of the Z-bar? It locates the bar cross-car. I recall wondering if the frame-side ball stud split-bushing was in the right position inside the bar, as that would definitely affect the cross-car location. Hope that's not too confusing...
