Color cut and buff.
You are welcome Russ69Runner. Attached is a photo of the glovebox lid and lower pad section after painting with the Herbs product. The entire interior looks the same
What’s Herb’s product? I need to do one and was going to use SEM
looking good Russ! Keep on trucking along! Want to see it done
Herb's mopar part's I have bought something's from them but no paint or any thing. They say they have dies and paint's for restoring dashes and all.
What does the back of your glovebox lid look like? I have a 68 and the front is really nice but the back is not very nice.
My mistake D. thought you where talking about the dash pad and glove box lid. Thanks for the support buddy. Russ.
Russ, your pics are outstanding. I do not paint, in my shop. I posted on another post (lost again) about what the back of your glove box lid looks like. Mine is not really finished very well. I don't know if I should finish it in some way.
I have had to order the glove box lid. Don't know how it look's on the back side. Figure to paint it with a flat black if needed but the vinyl looks good on the front. Use some armor all on it and it will look fine I think.
The face on mine is very nice as I said before but the back is not finished. The vinyl is wrapped around and glued on the back and not finished. The metal is exposed with some surface rust. I have many pics of my car just haven't figured out how to post them.
Just to say Big Mo I would tape off what I did not want painted clean the area good with like some 500 grit sand paper. If rust persist use 3part's water to one part vinegar and stainless steel wool on the rust. Let it stand for 15 minutes then Use stainless steel wool with clean water to clean it again. Let dry and prime. The solution will convert the rust. I have used this trick on most of my car in places. Maybe some one else will let you know just what to paint it with. I have used hot rod black which is an acrylic paint. Semi gloss. Use Rust Oleum rust converter you can get at lowes or some other hard ware store it works good. Then paint acrylic over that no problem.
