Crank Seal
gopkrz@q.com
AZ
Any thoughts as to what I should expect to pay to replace the crank seal.
Oil leaks more than I would like probably need to replace the Oil pan seal, value cover seal, and the crank seal.
Not sure I do my own but, if the crank has the old Knurling on it use a rope seal. If the Knurling is gone go ahead and use the Neoprene seal. I have followed this rule on the last 6 builds without a leak but I found out the hard way.
Are you looking to do this in car, or is the engine coming out for some reason?
Restorations By Rick in Buckeye might, if not he might know some one.
I would have to wonder why all of those seals and gaskets are failing. I would do a compression check. I bet that you have a lot of blowby that is pressurizing the crankcase. Also check your PCV valve.
