dashboard
hillsglass
Hi Guys I am trying to remove my dash,how many bolts on the bottom.Any suggestions
Thank's Chip
Thank's Chip
One on each end toward the front, just loosen them up and swing the dash down using them like a hinge and prop it up with something while you unplug everything and install the same way. The dash is slotted so they don't need full removal. I think there is room to change the dash pad in the car and not unplug everything.
are you wanting to remove the dash or the cluster? lf the dash frame the windshield has to come out to get to the bolts under the rubber.
Good point Dave. I was thinking the whole dash and the windshield was out.
good. and whlle you have the dash out best tlme to go over the asembly change the master cyllnder etc
A31PKG
Mid-Atlantic
hillsglass said:
Thank's guys, I am going to take the w/shield out
You're in luck because I hear the windshield gaskets are available again!
abodybill
Senior Citizen Member
MI. Farm
Yep they are out again but,close to $200.00.
I had went thru the glass company I bought my windshield from and it was $119.00 of course I don't have the correct tinted one like the stone chipped one that the car had. :eek:
