Dashlight insanity
mac
What ?
lancaster, new york
if you are sure that the switch is the problem i will look through my "stuff" and see if i have one.
SomeCarGuy
Sometown in KY
Thanks.
I'm not sure how to be sure. At this point it is just a guess.
The power at the dimmer wheel switches on and off with the flip of the switch. I would think that would mean the switch is good. Why is there no power at the fuse box? :brickwall:
The fuse box appears to be where the orange wires get their power. From a tan wire. I can't find the tan wire over on the drivers side anywhere to check. :brickwall:
SomeCarGuy
Sometown in KY
It is the dreaded dimmer wheel.
I had jumped the wrong terminals on it. Lots of dash lights now, especially since I changed out some of the bad bulbs as a part of this process. WOW.
I am short one "pod" at this point.
