Do you have to remove the trans to change engine rear seal
nicanor
I read the post about the problem with the leaking rear seal. I ordered the rear main seal kit from Mancini. The mechanic has never done a rear seal change on a Roadrunner and belives this can be done with the transmission installed.
So my question is: can you change the rear main seal with the transmission installed?
Thanks,
Barry
Hoosier Bird
Hope, Indiana
Re: Do you have to remove the trans to change engine rear se
You can do it without pulling the tranny. Not the easiest job but yes you can.
68rrunner
Old Saybrook, CT
I have seen it done, but I wonder if the time involved would be less if the tranny was removed.
generaljmwlee
NEPA
I change my seal 3 times already.finally got it to stop leaking by putting a rope seal in it.was the easiest real seal I ever did in the car with the trans in!
