rollie
- Joined
- May 14, 2013
- Messages
- 52
- Reaction score
- 1
After several near misses (since nobody these days leaves enough room between cars on the highway) ....... I'm going to switch to disc brakes. Can any members please advise the solutions that they would recommend that have worked for them in a similar situation. I currently have original 4 wheel stock 'manual drum brakes' on 15x7 rims with Magnum 500's.
I would appreciate any comments on the following options:
1) Upgrade to front manual disc brakes (perhaps from 72 Cordoba or similar)
2) Upgrade to new manual front disc brake conversion kit which includes spindles etc (eg Wilwood). Not sure if 3 or 4 piston calipers make a lot of difference on such a small rotor.
3) Upgrade to power assisted front disc brake conversion kit with booster. Note that I'm running a 383/496 stroker motor with Quickfuel 850. I've been told that stroker engines setups may not produce enough vacuum pressure?)
Any comments appreciated about your experience with your conversion from manual drum brakes to disc brakes. Thanks!
