I posted this probably last year, thought it was fixed but:
I heard the piston noise that they say is expected from using forged pistons and after a little warm up the noise was gone.
But when I first started the car and I could hear the pistons, then I stepped on the clutch pedal and could hear a bad bearing noise. Thought it was a throw out bearing but we put everything new into the clutch. After the car warmed up most of that noise went away also but if you depressed the clutch a couple of inches you could feel the clutch pedal vibrating.
So today we put it on a lift and had someone sit in the car and started the car while we were underneath the car and removed the clutch/flywheel inspection panel beefore starting. When we started the car there was no noise coming from the clutch area at all and watching the throw out bearing noting that it was operating properly. We heard noise coming from the oil pan area. It sounded like bad bearings but after the car warmed up, the noise went away for the most part. When we depressed the clutch the vibration was still there but the noise pretty much disappeared.
The engine builder still says its still only the pistons but I tried to explain the second noise and completely different noise but he said it couldn't be the bearing making the noise.
We pulled the oil pan and removed almost all the bearings. Don't know how to get the last bearing out against the engine rear by the rear seal without removing the transmission.
The bearnings all had score marks where the brass was showing and some pretty deep grooves. One bearing looked bad and as if was oval. The top of both sides of the bearing had no damage. As you moved down from the top 1/2 inch of the bearing the wear got worse and worse and was really bad the bottom part of the bearing. Oil pressure was fine. Another engine builder said the bearings might have been on too tight.
Any help or good questions to ask the new engine builder would be helpful.
Thank you,
Barry
Thank you,
Barry
