Flasher help
Moparnut
Western NY
I am in the process of sorting out problems with my project. The headlights work, highbeams work, running lights work, both turn signals work. The flashers are giving me troubles. When I turn the flasher switch on, only the front left bulb flashes! I changed the flasher under the dash next to the steering column. Is there a second relay? Anything else I should check? Any help would be much appreciated!!
Check the ground to the front turn signals by running a jumper wire to the bumper.
Moparnut
Western NY
I'll try, but the lights work fine with the turn signal switch and the headlight switch, so I wasn't thinking it was a bad ground. I bought a wiring schematic and it shows 2 flashers, so I'll try to locate the other one and replace it.
Yep, there's two flashers. Both are under the dash.
That said, you are having the classic bad ground symptoms. What happens is the parking lights etc. will work because they get the ground feeding back through the other lights.
The front bumper is bad for this. The ground comes from the brackets mounting to the frame and if your car is either a little rusty or even if the brackets and frame are painted up nice, you won't get a good ground.
Moparnut
Western NY
I got them fixed; tried a ground jumper, but no dice. I cleaned the connections at the switch and changed the relay and all is good. Thanks for the help!
andy69
Australia
now that where talking about flashers,mine only work when i turn the left indicator on....go figure :huh:
