From the column to the floor?
woodwiz
Tucson,Az.
Do you all have some input on moving the shifter(factory) to the floor from the column? Seems like their may be more to it than just getting the parts together. It’s the torqueflite in the 70RR. As it is now I have the split bench seats which would require a set of buckets instead,which may be a little spendy. I like the factory console look and function,but I’m sure someone will suggest it ain’t worth it.
That is if you can find the console parts and shifter.
Any ideas would be welcome.
Thanks!!
I believe all parts are available. Just decide what you would like the car to look like and go for it
