Front leaf spring hanger bracket.
Got mine ready to put on had them off for some time. No arrow to point which way they go. I had marked left and right on them but did not put up or down. So thinking the spring eye bolt should be down. Any info on this would help want to do this once. Russ. Oh I did look in manuals but cant tell from the picture.
Ok I got it can't put it on wrong. Two bolts closer together than the other two bolt's. Guess that is the reason I did not mark up or down. Thanks Russ. :screwy:
I was about to say LOL. Did yours come with the car? Asking because the Dodge hangers are longer for the longer wheel base.
Yes they where Original to the car. After looking saw two bolts where closer together than the others. Figured that is why I did not mark up on them but did mark L and R so I would know which side they came off. Thanks. Russ. :thumbsup2:
Yep that is what happens when you have the car apart for too long and don't take enough pictures. Russ. :thumbsup2:
