Fuel guage not working
pinkpanthr
Kentucky
All of my guages are working except the fuel guage. I installed a new fuel tank and sending unit but still nothing. Any suggestions?
I think you will find all kinds of good reading on the subject in the tech section
69383RR
up state vermont
Did you ever get your fuel gauge to work ? I replaced my tank and sending unit as well and the gauge didn't work either so like 4spd said I checked for lose wires and sure enough I found one , problem solved .
inri
Check the ground wire that is on the back of the tank
pinkpanthr
Kentucky
Yeah, mine was corrosion on the nuts that connect the gauge to the circuit board. I replaced the circuit board because the old one had a broken pin and bingo, working gauge.
