gear venders overdrive unit
[attachment=0:1vjilj7y]gear venders overdrive.jpg[/attachment:1vjilj7y]yeah baby its here....now to just install.....WHOA!!!!!!!!!!!!
BBillyC said:
Very nice. Any mods to the drive shaft required or is this plug-n-play?
yes i have to shortin up the driveshaft....send it back to mark williams....cut and rebalance at 7500rpms,,,,everybody else balances them up to 1200rpms.....also change tranny yoke ...the one gear venders sent.....1350 u-joint...which is the same on the back end....i have to remove line -loc button off stick pistol grip and install there new button also
zupanj said:
George,
You said six-speed 727? How many speeds in the overdrive unit?
Jack
3 forward speed with the overdrive off...3 forward speeds with the overdrive on...that would be six available forward speeds...
ACME
George. I had a U.S. Gear in a motor home some time back and it used an electric motor to shift up and down. Is that what yours has? It had straight cut gears so you had to let off the gas to relax the drive train to get a smooth shift. It worked good :cheers:
FROM WHAT I AM READING ....ELECTRIC/HYDRUALIC....AND I AM HEARING THERE IS A DELAY FOR IT TO SHIFT....i will find out after the test drive....after my wifes honey due list is done
